  1. to convert avi2dvd + D2SRoBa
    when D2SRoBa takes charge i get this eror.....
    i dont know what to do, this is the only movie that it is happaning to me with!
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    got any room on your drive ? or writting to the right drive ?
  3. You may be having an Avisynth problem.
    Delete your configurations settings file and redo your setup from scratch.
  4. isnt it strange that the problem is only in 1 movie!??
    i've done more than 20 movies with this configurations!
    any other advice before i take this extreme one?
  5. Why extreme? All you have to do is uninstall dvd2svcd
    and avisynth and re install them.
    You could try www.doom9.org to check if they
    have a solution - they host the premier dvd2svcd forum
    on the net. You might want to include a link showing
    your log file.
