I am having trouble converting some .mov files that i downloaded from ign.com. I used Tmpgenc 2.01.30.116 but it crashed or came up with an error message when i tried to convert the .mov files (i did install the mov reader file). It works with avi files so i decided to convert the mov files to avi files with quicktime but the quality was severly degraded. Is there an encoder that will do this mov to mpeg converting or even a vcd burner that allows movs aswell as avis and mpegs. I'd be glad for some help
<font size=-1>[ This Message was edited by: Gremeos on 2001-12-02 07:08:02 ]</font>
I haven't had any problems using Quicktime to convert to an .AVI, make sure when you export you check the options button, set no compression, millions of colors, quality Best, and frame rate 29.97. Like I said with these settings, and a good original, I've had flawless results!
incase u r needing a little more information, i use PAL conversion, and the avi file from quicktime was very blocky.
mpeg streamclip - .mov to .avi
By AirFox in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 18:19 -
MOV to mpeg conversion in TMPGEnc4XP
By jay_lubb in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2010, 02:16 -
Converting MOV to MPEG-2 File
By cyberboy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 17:39 -
Converting MOV -> MPEG-2 (or AVI or...)
By Sean-PH in forum ffmpegX general discussionReplies: 5Last Post: 10th Jan 2008, 13:35 -
MOV or DV to MPEG-2
By mused13 in forum MacReplies: 5Last Post: 12th Oct 2007, 16:41
