Results 1 to 9 of 9
  1. Ok,
    I converted some avi videos to a dvd format using WinAVI 5.8, each Avi file i convert get it seperate Video_TS folder. Is there a way that i could load all these avi conveted to dvd files on one dvd for play back in a DVD player. Would i have to make a menu using something like DVDremake Pro?
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    You could import the VOBs into TMPGENC DVD Author, it has a quite simple interface and is easy to use.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    That's what I'd use too. It has a 30 day fully functional free trial.
    If in doubt, Google it.
  4. i got some sort of warning nad tmpgenc didn't let me add it. :< ARGGGH!
  5. is there a way to do it with DVDremokepro or something
  6. but when i use the tools...dvd to dvdr it allows me to add it. but only one dvd at a time.
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    @ken.vs.ryu:
    Nice threadjack
    Are you planning on telling us the error message you got, or do we have to guess ?
    @Binary89:
    I personally don't know whether you could do this with DVDRemake Pro or not - I don't see why you couldn't. How you do it with that program is another matter though.
    With TMPGEnc DVD Author, all you need to do is use the Add DVD Video button and point it to your VIDEO_TS folder. It should then give you the choice of titles to import. You can add as many different titles from as many different DVDs as you want, size permitting.
    I'd suggest that both of you might try the guides section. In particular, the authoring section.
  8. wtf? what happened to my thread?
    well the error was in crazy characters.
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd suggest that this thread is your thread
