  1. Member Sakuya's Avatar
    Dec 2002
    I have the Media Player Classic (the one with tons more options than the pre-installed Windows Media Player 6.4). Whenever I stream a file online, that address gets saved onto the address bar in the player (File, Open File, that address bar). How do I clear that address bar's contents? I already deleted the Temporary Internet Files and History using IE's Internet Options tool.
    In the Media Player Classic options, I did uncheck "keep history of recently opened files".
    Australia
    They are held in the "\Program Files\Media Player Classic\mplayer.ini" file under "[Recent File List]" - you can edit this file and delete the list.
  3. Member Sakuya's Avatar
    Dec 2002
    My Media Player Classic only came with an EXE file. So I just played it on my Desktop.
    Australia
    In that case have a look in the Windows registry under ..
    "HKEY_CURRENT_USER/Software/Gabest/Media Player Classic/Recent File List"
    it puts all the stuff here if it can't find an INI file.
  5. Member Sakuya's Avatar
    Dec 2002
    Uh...what do I type in the Run box again to open the registry? I forgot.
    Australia
    "regedit"
    (and you could also then use the search tool to look for "media player classic").
    and quit watching those movies!
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Another good method is to use the newest version of adaware and remove the MRU's in the neglible objects tab (most recently used list ). Works like a charm and clears lists from other windows settings too
    Kevin
