What does mean?
I'm running a .avi (720x480, PICVideo) through Vdub (.avs file). No Audio, just video. Makes the new .avi just fine.
Load the new .avi into CCE and setup the settings I want, I get the above error? Any ideas? Thanks.
I'm encoding to 480x480 MPEG2
https://www.videohelp.com/phpBB/viewtopic.php?topic=63385&forum=3
Is there any reason why you use both VirtualDub and Avisynth? -
Here's my process, I cap with AVI_IO (I get less frame drops with it, than vdub) at x480 (720 or 640).
I then load the Avisynth (GreedyHMA)/Rezise (480x480) .avs into vdub, and do a direct stream .avi
I now save with the old format .avi, after reading your post. CCE works now, however.. halfway through the vdub/.avs process I get: AVIOutput - error in parimeter (or somthing to that effect) any clue on that?
Is there a better way? TMPGenc is just to damn slow. -
Yes. I loaded the handler, and turned the proxy on. Howeverw hen I goto load the .vdr file in CCE, it says that its not a .avi file. Even if I name it "blah.vdr.avi"..
I meant to frameserve with Avisynth but without VirtualDub.
Load the .avs into CCE instead of VirtualDub. Or do you use cce sp 2.62?
Also you said, you selected direct stream copy. Then the avi will be saved as uncompressed avi and if you running Win98/ME you'll get after 4 GB the parameter error message.
Solution: Save as segmented avi. There is a way to frameserve segmented avi to CCE 2.62. Convert the .avs (SegmentedAviSource) with VFAPI 1.03b and open that pseudo avi in cce. -
Ah, forgot about the 4GB limit. Yeah, I have SP 2.62.. just got 2.5, but still naged.
cce sp 2.62 accept mov and avi only (vfapi.avi too)
cce sp 2.5 accept .vdr, .avs, mov, avi (vfapi.avi too)
Run Vdub's proxyoff.reg before using VFAPI.
VFAPI 1.03b converts .vdr and .avs. VFAPI 1.04 do not.
VHS to DVD conversion - Am I expecting too much?
By Office Linbacker in forum Capturing and VCRReplies: 163Last Post: 2nd Apr 2014, 11:56 -
I need some sound bytes if that is possible.
By ingeborgdot in forum AudioReplies: 4Last Post: 25th Apr 2012, 21:53 -
Need number of bytes played per millisecond
By rpolavar in forum Newbie / General discussionsReplies: 14Last Post: 27th Aug 2010, 01:41 -
says it succeeded but file is 0 bytes in size
By mlevin77 in forum ffmpegX general discussionReplies: 6Last Post: 21st Oct 2008, 18:04 -
Bytes of a movie
By Jomapil in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2008, 10:58
