Ok so a friend of mine was telling me if you have a DVR burner capable of burning data in dual layers, then you can use a 4.7GB DVD-R and actually burn over 8GB of data...is that right? If so, does the DVD software recognize the disc as 4.7GB or 8GB?
I also heard something about being able to get 16GB off one DVD-R? Is there any truth to that? thanks.
There is +r DVD media that are 8.5GB , 4.7GB DVD's are 4.7GB, i have never Bought a DVD that was 16GB.
Edit: There is no DVD-r that is 16GB
To burn Dual layer you need a Dual layer DVD burner. -
You have to use media that actually has 2 physical layers. The burner cannot just create a new layer. One of these:
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Holy crap those blank DVD-r DLs are expensive. Anyone anticipate they'll drop within the next millenium?
they dropped a lot already, from 16 euro to 6 euro her in europe in a half year, so i think they will drop very slow now.
its not worth to burn data on it, when you are able to burn it on a 4,7 gig for 1 euro (if you use high quality discs).
and its not worth to copy movie dvds with it, becasue a few euros more and i can buy the original again.
i really would like to know who buys 8.5 gig for 6 euro? if nobody would buy it it would drop like hell. i will start to buy it when they cost below 3 euro, but i think this will not happen the next 10 months
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Formatting dual layer DVDs before recording?
By Emmabarn in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2009, 23:10 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
dual layer recording
By flezar in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2008, 15:57 -
Recording on a Dual Layer DVD 8x
By Avto in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2007, 13:55
