how do i burn 2 divx movies converted via winavi onto 1 dvd? i have 2 disk_0. i renamed one of course.
Results 1 to 14 of 14
did you select add dvd video?
when did that error appear? -
new project - add dvd video - select disk_0 folder - errorOriginally Posted by Baldrick
tried dvdshrink - reauthor - add dvd - doesnt recognize disk_0
winavi outputs the conversion into a folder named disk_0
it contains
12/21/2004 06:56 PM 8,192 VIDEO_TS.BUP
12/21/2004 06:56 PM 8,192 VIDEO_TS.IFO
12/21/2004 06:56 PM 20,480 VTS_01_0.BUP
12/21/2004 06:56 PM 20,480 VTS_01_0.IFO
12/21/2004 06:56 PM 838,057,984 VTS_01_1.VOB -
Inside the disc_0 folder, create a new folder and call it VIDEO_TS. Move all the files into this folder. Repeat for your other disc_0 folder (the one you renamed). Now point TMPGEnc DVD Author the the first VIDEO_TS folder using the Add DVD Video button. Once it has imported that title, repeat for the second one.
If in doubt, Google it. -
i get the same error. the folder name doesn't matter since when i use Tools Menu - "Write DVD folder to DVD R/RW" I can add the DISK_0 folder fine. But it only allows 1 folder at a time.Originally Posted by jimmalenko
this should be a very common procedure! no one else has done this before?
Yes, many many many people have done it before - the way I'm telling you to do it !Originally Posted by ken.vs.ryu
Unfortunately you are not listening/reading following isntructions properly. You cannot do it in the "Write DVD folder to DVD R/RW" part, you must create a new project, then use the Add DVD Video button.If in doubt, Google it. -
1. yes i renamed the folderOriginally Posted by jimmalenko
2. i created a new project
3. clicked on add DVD video
4. selected your VIDEO_TS
5. get the same error -
1. start winavi
2. click on dvd
3. select all files to be converted
4. it will out put to one disk_0
use your favorite dvd burning tool
help please, no sound when I've converted with winavi
By loadabull in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2011, 04:57 -
Any considerations when burning WinAvi converted dvd to a DVD+RW?
By AshleyQuick in forum Authoring (DVD)Replies: 2Last Post: 26th Jan 2009, 19:31 -
Need to find missing files that I converted using winavi
By azulbonita in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2008, 08:22 -
Audio becomes out of sync when converted (transcoded?) from .vob files
By Neptuna_Fish in forum Newbie / General discussionsReplies: 12Last Post: 21st Aug 2007, 20:39 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 19:26
