  1. Hey, any idea what causes this? Also, why does it look checkered when you zoom in, do all tv tuner cards to this?
  2. Member vhelp's Avatar
    Mar 2001
    New York
    Here's what I think your issues might be
    The Ghosting is most likely a part of the source. That's ben my
    experience too. I think it's everybodys NTSC/PAL. There's nothing
    you can do about that - except for filtering as much out of it as
    you can, if there is a filter for just this thing.
    The Checker Box (in those red areas) might be due to your s-video wire
    quality, and/or tight or loose fit on connectors. Every area of a
    given conntion/connector should be clean too. Well, that would help.
    The other cause could be the station airing the source, that it could
    be the fault (most likely) and only your S-Video is capturing it because
    it is not performing a Comb Filter (much like Composite does, in a way)
    Using composite connection might cure this, but remember above, that it
    might be only "blending" thereby hiding those checker box's.
    -vhelp
  3. That ghosting is most likely from oversharpening.
    The checkerboard pattern is dithering by the encoder or decoder to reduce banding from a reduced color depth source. The oversharpening exacerbates it too.
    And some of it is not visible on the tv anyway...
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I get ghosting a lot because I have my main antenna split to two tvs WITHOUT a booster So there are some lines like that occasionally. That gets captured and not much I can do about it. (standard broadcast - not HDTV).
    Kevin
  6. Thanks, that helped somewhat. I just hope my satellite receiver isn't causing it because I really don't want to buy another. It's a Toshiba TRX 1820 C-band receiver so it's sort of 1980's technology but it's supposed to be a good one (one of only 3 brands that had s-video). One thing I noticed is if I bring an on screen menus up, they also have the ghosting lines around them. So it might be the receiver after all.
  7. Yea, the dish is like 230 feet from the receiver.. I used RG-11 but maybe that's not enough.
