Hi,
right now I own a regular single-layer DVD burner. However I have copied a dual-layered DVD to my harddrive (iso files) with dvd decrypter.
My question is:
if i buy a dual-layer burner for my computer, will DVD decrypter be able to write this iso files to a dual-layer DVD-R? Will i just be able to insert the recordable dual layer disc and choose write mode, then select that ISO file and burn, as I am currently doing with single-layered DVDs in dvd decrypter?
or is dvd decrypter not able to handle dual layered dvd's?
thankful for any advices...
i have the latest dvd decrypter, yes.
But will it work even though the dual layered ISO files was ripped with older versions of dvd decrypter? -
Probably not,v3.5.0.0 fixed the error.
Only one way to find out...burn one.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Burning AVCHD File To Dual Layer DVD
By Falco21 in forum Authoring (Blu-ray)Replies: 4Last Post: 15th Mar 2011, 11:16 -
Dual-Layer burning of DVD using nero?
By mr_jbloggs in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2008, 07:26 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
Burning dual layer dvd-r from mac the ripper
By alforra in forum MacReplies: 11Last Post: 18th Apr 2008, 21:08
