  1. i have tried dr divx to make a back up divx of one of my dvd collection , it seemed to work ok but the problem is it has included the dvd menu of my original dvd which seems to kind of mess up the actual option of playing the film , the options are all there but do not enable when i try to click them so i never can get the film to actually play , should i have somehow removed this dvd menu before using dr divx and if so how do i properly go about this procedure ?
    cheers
  2. Sorry I am confused at what you are trying to do.
    Are you trying to take a dvd on to another dvd?
    If it's wet, drink it
    My DVD Collection
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Sounds like you've included the menu file (VTS_xx_0.VOB) in the conversion process.
    DivX's and XviDs can't have menus yet AFAIK. Just run Dr DivX on the VTS_xx_1.VOB file and onwards for the complete titleset.
    If in doubt, Google it.
  4. many thanks for the info i will research further into this following your tips all the best
