I am backing up DVD's using DVDFab. Everything works except on every cd, at exactly the same time, around 9 minutes into the video, the video glitches and the DVD player goes to the start of the DVD. Does anyone know anything about what the possible cause of this problem might be? Could it be the media, the drive, or DVDFab is not creating compliant images.
I use DVDFab to rip the DVD and then put it into image files, then use DVD Decrypter to burn. As well i have used DVDFab to rip and burn all at once, and both methods have the skip problem. That is the only problem, if you fast forward past that part, it works no problem for the rest of the DVD. When splitting to two DVD's each dvd will have that glitch at exactly the same time. It is not at a chapter split either.
Any information on where to persue the solution to this problem would be very helpful.
Not bothered by small problems...
Spend a night alone with a mosquito
Repeated VHS Dropouts
By NitroPress in forum Capturing and VCRReplies: 2Last Post: 3rd Mar 2011, 09:03 -
MPEG-4 frame skip problem - any way to fix it?
By TMHKR in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 07:42 -
DVD Architect pro 5: problem with playlist, brancing and next (skip) button
By alfini in forum Authoring (DVD)Replies: 0Last Post: 25th Oct 2010, 06:28 -
Repeated GUI Crashing
By Eva-Unit01 in forum Video ConversionReplies: 0Last Post: 8th Mar 2010, 07:48 -
Repeated Lacie Drive Failures!
By Deane Johnson in forum ComputerReplies: 1Last Post: 9th Nov 2007, 09:32
