I've been using DVD-Lab for about a year and I'm comfortable with it, but I also have Sony's DVD Architect II that came with Vegas5. Which do you guys prefer? Are there any specific advantages of one over the other?
The only differences I've noticed is that DVD-A2 seems to normalize my tracks/menus/1st plays whereas DVD-Lab doesn't. Also, IIRC, DVD-A2 will re-encode your audio to ac3 to keep things compliant.
Results 1 to 12 of 12
DVD Architect 2 doesn't do subtitles very well. I couldn't read them very good since the only thing it supports is an outline, and it is a very thin outline. DVD-lab doesn't support subtitles the last time I used it but DVD-lab pro does and it has a bunch of effects for subtitles to make them easier to read. Besides subtitles they seemed about the same to me.
Unless Sony have fixed it, good luck lining up items in your menus. The last time I tried it (version 2 but I gather there's a v2.0b or newer now) there was no 'snap to grid' or similar to help give you a neat, consistant look. The only workaround for that is to use an external editor.
Personally, I would stick to DVDlab since Oscar is very open to receiving program enhancement requests. I feel that DVDlab will move on much faster than most other authoring software. Possibly it won't 100% comply with DVD standards (at the moment) but name me one authoring program that's guaranteed to author a DVD that will work on every single player out there. Besides, DVDlab has a lot more features than most other similar software available so pretty much all there needs to be done is work on compliance with the DVD spec. Oscar's also quite active on the Mediachance forum and actually cares about his product - sometimes it's nice to talk directly to the developer when you need to. -
Originally Posted by BJ_M
A few?
Originally Posted by Josef K
dvd lab is not in beta -- dvd lab pro might be ... i was refering to dvd lab (the basic program)
anyway - i wasnt knocking it either !
its a very good program for the money it seems ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Of course it screwed up something else in the menu creation.Want my help? Ask here! (not via PM!)
You could always Ask Sonia...
My name is Sonia. I’m not a real person, but I can understand and answer your Sonic questions. You can ask me about:
DVDit
MyDVD
RecordNow
Here are some tips on having a session with me:
Hmm... Dear Sonia... -
it makes me cry how sonic ruined a perfectly great program like Recordnow Max ...
[DVD Architect] Making ISO image (DVD DL)
By Madras in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2012, 15:27 -
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 12:28 -
MKV to DVD uisng DVD Architect w/ 2 audio 1 sub (I have searched forums...)
By Dratheus in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2009, 18:16 -
DVD Menu Studio export to DVD Architect
By sir_rob in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2008, 18:18 -
DVD architect
By Abiyad in forum EditingReplies: 1Last Post: 19th May 2007, 08:02
