I've been making SVCD's for years...Xmas...got an early present..a DVD Writer. I probably know the answer to my question but just to be sure I thought that I'd ask the experts.
DVD Decrypter can make images of DVD's that can fit on a single DVD(dual layer too) So, if the image fits on the DVD-R,, would I get a better picture if I ripped the VOB files then did a 4 pass encode with cimemacraft or TMPGENC? My thoughts are that you can't make the picture better than the original..kinda like that junk in, junk out thing.
So, do i re-encode the video or just use the image file that DVD Decrypter makes? Thanks
Rique
If the DVD is a DVD-5, you would just decrypt it and burn it for the best quality. No need to encode or shrink. However, if it is a more common DVD-9 you would either have to shrink it or re-encode it. You would get better results (IMO) with a re-encode but at the expense of a lot of time and more effort.
DVD Shrink is a common "re-coding" program for putting dual layer disks onto one DVD-r. It's fast and if you select re-author and lose the menus and extras, you can sometimes burn to a disk with little or no compression involved. For longer movies and higher compression requirements you're better using an encoder or splitting to two DVD-r's. As for when you switch from DVD Shrink to an encoder...well that would be for you to test and decide.
Encoding question??? Need advice please
By Tony Cymmerman in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2012, 17:55 -
Creating menus: DVD Styler re-encoding question.......
By bahjan in forum Authoring (DVD)Replies: 3Last Post: 21st Dec 2011, 05:54 -
Encoding Question
By ne0natas in forum Video ConversionReplies: 1Last Post: 7th Feb 2011, 20:46 -
By Mauserman in forum ffmpegX general discussionReplies: 2Last Post: 17th Feb 2009, 15:42 -
audio encoding question
By spittle in forum AudioReplies: 1Last Post: 26th Jun 2007, 17:47
