    Apr 2003
    (converting divx to DVD-R) after using dvd2svcd i tried loading encoded_video_pal.mpv file and my .ac3 fix file(used ffMPEG) and am getting this message! How do i fix this? i sent an image for you to see
    thank you
    let me know if my image shows up-im not sure i did it right
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Originally Posted by lowrunner
    ...let me know if my image shows up-im not sure i did it right
    Nope.
    Apr 2003
    oh well heres what it said my problem is:
    "The Combined bitrate of the clip exceeds the upper limit for a standard DVD
    the combined bitrate of the video and audio of clip "Encoded_Video_CCE_PAL_mpv"of track"Untitled track1" is exceeding the upper limit for a standard DVD.
    The current bitrate is video: 9800Kbps, audio: 224kbps, combined: 10024kbps.
    The combined video and audio bitrate can be no more than 9.848Mbps (9848kbps)
    ok what can i do to fix this problem? im new to this so i hope im not being to anoying!
    thank you
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    I would just try the ignore button and see if you have any problems playing it.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    In the future, lower your video bitrate down a shade, and you won't see that error message again
    If in doubt, Google it.
    Apr 2003
    when you say lower it a shade do you mean enough so that the video and the audio bitrate add up to 9848kbps ? sorry if that sounds stupid
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Not stupid - spot on, actually
    Lower the video bitrate until your combined bitrate is 9848kbps or a little lower, and you won't see that error message again
    Apr 2003
    thats what i meant. thanks ill try that
    i appreciate the responses
