Is anyone making xvcd with Query VCD Maker Personal?
I get an error message when making an image with xvcd.
I have tried cheating bit rate and fixing pack sizes but VCD Maker would not take a xvcd mpeg file.
Is there other way to cheat the app?
try using VCDGear and converting the MPG to BIN by selecting the Toast Ready option. Then burn with Toast in VCD mode.
Thanks major.
but I am trying to make VCDs with menus by VCD Maker.
So I would like to find the way to go xvcd with VCD Maker, not with Toast. -
Can you burn XVCDs with toast by converting incompitable mpgs to .bin with vcdgrear?
yes, you can burn many kinds of XVCDs that way, however MPG packet size must be 2324.
slow_hand:
To make VCD, SVCD, or XVCD toast ready .img files that support menus, you may need to author a xml. Then use vcdToolsX create the tracks. Toast will love them. Will VCD Maker output the xml?
https://www.videohelp.com/phpBB/viewtopic.php?topic=64874&forum=9 -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
VCD Maker won't make xml, I believe. But simpley it outputs image files. It comes with GUI to easily operated. You drag and drop mpeg files and pict files(for still image) and draw lines inbetween them.
HD Audio Query
By anirban in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2011, 11:08 -
DVDStyler query...
By mjl1297 in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2010, 05:36 -
Vegas 8 query
By Fukushuu in forum EditingReplies: 6Last Post: 1st Feb 2009, 21:41 -
iTunes query
By melted_moonlight in forum AudioReplies: 0Last Post: 25th Jul 2007, 12:51 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 22:18
