  1. Hi,
    I just completed a reformat and fresh install of XP Pro. XP does not see my second HDD. BIOS sees it, but XP doesn’t.
    WTF! I’ve had WIN2K on the same box/hardware, plus an XP Upgrade, all of which have seen my second drive.
    Any suggestions please???
  2. Have you tried Settings > Control Panel > Adminstrative Tools > Computer Management
    Then go down to Storage > Disk Management
    ...and seeing if it's listed?
    You might have to right click it and hit Import Disks.
  3. Originally Posted by freestyler
    Thanks, that was fast! I will try that and report back....
  4. I had an issue where my slave hard drive would sometimes be visible and sometimes not. Turned out to be a faulty IDE cable. May be worth checking that the IDE plugs are seated properly in the hard drive's socket.
    Hope that this is helpful.
    Cole
  5. Originally Posted by freestyler
    Thanks, Free…
    I found it there, but unfortunately I had to reformat the drive. Only thing I can think of is that during the XP install, I may have deleted the partition on that HDD. This is weird to say the least, as I have never had a second HDD come up in the basic install/format. I had TWO partitions on the basic system drive prior to the install. I wanted to get that drive back to a ONE partition drive, so I deleted all partitions. I might have deleted the partition of the SECOND HDD without realizing it! But this has NEVER happened before.….
    It’s not a total loss as I have a backup of all the data… just, now I have to figure out how to network in XP to get the data back over there (separate computer).
    Anyway, as I type I am sure I will have a recognizable second HDD after the format which is occurring right now. I just need to figure out how to network the TWO XP computers so I can get the software backups to the fresh XP box.
    Thanks!
  6. Originally Posted by freestyler
    No problem Paul
  7. Next time try Partition Magic, it can take care of this for you.
