I am trying to make a DVD from an avi video clip/movie. In order to use the TMGenc dvd authoring program I am first trying to use TMGenc program to convert the avi to mpeg. The size of the avi is 651 MB (682,962,944 bytes) approx. 1hr and change. The glitch is when I try to use TMGenc to convert this avi it says the size of the video exceeds 4.7 GB capacity of the DVD and is 278 minutes???? Why the change in size or am I just doing something wrong. I have gone over this several times and cannot figure out what I am doing wrong.
Results 1 to 12 of 12
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks for the input. It does not seem to have mp3 audio. Also - what I tried was to use Nero to create a TS folder, which it did. Then when I went to use the TMGenc dvd authoring program I was told the "combined audio and video bit rate exceeded limits for normal 4.7 gb dvd??? The length of this movie clearly was not exceeding 4.7. Am I missing something here??? Still looking for answers.
Originally Posted by deanst2
Second, read that error message a little more carefully. My interpretation is the the bitrate of your audio+video combined is too high for DVD standards, not that the file is too big. -
"My interpretation is the the bitrate of your audio+video combined is too high for DVD standards, not that the file is too big."
That's right! Now, what does that mean and how can i adjust it so the bitrate of the audio and video combined is not too high for DVD standards.
What I am trying to do is take a movie recorded as an .avi and put it on DVD. I first have to convert it into proper format. That is what I was trying to do with TMGenc. That didn't work so I used nero, which produced a format that the TMGenc DVD authoring program could work with but then I got the bitrate statement noted above when I tried to burn it. -
Originally Posted by bugster"Art is making something out of nothing and selling it." - Frank Zappa
What does this mean? -
I would try the "ignore" button and see if it plays. Otherwise try a different encoder, as previously suggested."Art is making something out of nothing and selling it." - Frank Zappa
Can I change the file size of a video?
By ivansmom in forum Newbie / General discussionsReplies: 4Last Post: 3rd Feb 2011, 19:04 -
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 14:04 -
Can't change the file size
By spiro murray in forum ffmpegX general discussionReplies: 3Last Post: 11th Mar 2009, 21:48 -
Change the file size ?
By sat-jokar in forum Newbie / General discussionsReplies: 1Last Post: 27th Feb 2009, 18:32 -
How to change picture size
By hilario in forum Video ConversionReplies: 18Last Post: 24th Mar 2008, 08:04
