Hi,
I've just bought Natalie Imbruglia latest CD and tried to rip it. I could not do it.
I wanted to copy only the tracks into wav files and create my own best of album.
Any idea ?
Results 1 to 12 of 12
Goto Gamecopyworld.com They have heaps of info on how to crack copy protection.
If you just want to make another copy of that CD, try CloneCD.
I only dream in black & white...
MSN: paschendale@gmail.com -
Why not press play, and use http://www.goldwave.com to capture it
or even Windoz sound capture.
If you can hear it, you can record it
If this is one of those new audio CD's that can't be played in a PC then you might be in trouble. Clone clinic's forum will probably have a solution. You could always try isobuster if it's being a bitch.
Hey,any of you have a link where I can read up on this new copy protection? This seems very interesting.
GameCopyWorld.com is hard to navigate.But I found the link that my interest everyone who has trouble with copy protected cd's and stuff.
http://www.cdmediaworld.com/hardware/cdrom/cd_protections.shtml
And here's the link to your solution.
http://www.cdmediaworld.com/hardware/cdrom/cd_protections_cactus_data_shield.shtml
_________________
Obey Your Thirst,Sprite!
<font size=-1>[ This Message was edited by: VCDsMakeMoney on 2001-12-02 13:29:11 ]</font> -
Thanks for everyone's answer.
Unfortunately my Yamaha 4416S CD writer does not support RAW mode required by CloneCD.
But my plan was to rip only the tracks into wav files, and I think this CloneCD can only duplicate the disc.
Any more idea ? -
have you tried using the wav output plugin in winamp to create wav files for all the tracks? remember we used to do that all the time before you could rip straight to mp3.
WinAmp does not work.
Also tried Isobuster and it gives "The Primary Volume Descriptor is unreadable" message.
I'll try more... -
If you can play it in your comp cd drive Goldwave is a easy answer. I havent tried to play cactus protected cds in comp drive so i dont know, maby it doesnt work..then if you have a soundcard with line in, take it that way from reg audio cd player.
the easiest way is to go back with it to the store and demand a new. I know that atleast here (Sweden) BMG have been taking CDs back (HIM and Natalie Imbruglia latest) due to that thoose cannot be played in all players due to the cactus
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
There's a program out called "CDFS" that seems to bypass the protection. What it does is replaces Win95/98/98SE's own cdfs.vxd file with it's own. The CD now looks like a regular disk to your computer and you can drag the music files to your hard drive.
Searching for "cdfs.zip" via Google or any other search engine turns up several results....
Finally I have the solution!
I have found two programs which can be used partly in my configuration where is no RAW mode supported CD Writer.
1. EAC (Exact Audio Copy freeware) could copy the 1-6 tracks without any problem but never the 7-12 tracks.
2. CDCopy v4.801 (Markus Barth shareware) could copy the 2-12 Tracks but never the first one.
I do not understand why, but anyhow I have the full disc ripped.
I hope this info helps someone.
DVD player's copy protection won't even let me rip home movies.
By Brian. in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th Mar 2011, 15:12 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
DEJA VU Rip - New Copy Protection?
By crjackson in forum DVD RippingReplies: 8Last Post: 9th Aug 2009, 00:21 -
how to rip an audio off the net, when the audio is blocked/protected?
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2008, 10:14
