Every time when I'm converting avi to vcd using virtualdub, and after some minutes the computer suddenely restarts by itself.
very strange.....
I wonder what's wrong.
Results 1 to 15 of 15
avi to VCD? Not exactly your typical use of VDub. How exactly are you doing it?
I know that VirtualDub can convert MPG to AVI but was unaware it could do the opposite ... AVI to MPG. Could you post the step-by-step procedure you follow?Originally Posted by Kebhe
Are you frameserving?
Check your CPU temp while you're encoding. Also, be sure not to knock your knee against the 'Reset' button on the case... :POriginally Posted by Kebhe -
Insert more fans, add silver thermal paste to the processor, and get a better cpu fanOriginally Posted by Kebhe
http://www.sofotex.com/cgi-bin/ls/page.cgi?page=download&link=9326
AIDA32 will have a tab which will show you your CPU temp. Look under "Sensors" -
from the beginning the converting worked very perfectly, but now it's very strange.
isn't there any other reason than overheating?? -
Faulty or incompatible ram will reset your computer especially if you are pushing your resources to 100% use.
Removing VirtualDub from Computer
By Sidus1 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2010, 18:04 -
weird computer problem
By lordhutt in forum ComputerReplies: 5Last Post: 1st Dec 2009, 16:45 -
By deadrats in forum ComputerReplies: 23Last Post: 24th Jul 2009, 20:10 -
Problem playing dvd's on computer
By easye35 in forum Software PlayingReplies: 5Last Post: 18th May 2008, 01:30 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08
