anyone have any problems backing up Bourne Supremecy?? DVDSHRINK and Recode seem to crash about two minutes in to it. i also ripped it with DVD Decryptor, successfully, then started shrink and Shrink still crashed.
Results 1 to 9 of 9
Forum search is your friend
Someone else had this issue and the fix was to make the Unreferenced Material uncompressed or still image. It might just be a certain region release of the DVD I think.If in doubt, Google it. -
I had the problem, but after using DVD Shrink I got it to work. Check out the other thread....
jimmalenko---you were right, take the unreferenced material and turn it to a still and it worked!!!
thanks
ps--i did a search and the thread with the info never came up. i thought i had seen that thread, and in fact i had. i just coudn't find it. -
How come no one uses dvdxCopy express? That never has a problem backing up movies, plus you dont have to use TWO programs (dvd shrink + whatever else to burn it). It seems silly to use to programs to back up a dvd.
DVDshrink and DVDdecrypter are free. You can save the $90 and spend it on blank DVDs.Originally Posted by mattyboy
Also, you don't use both programs to back up a DVD, only one or the other. I usually use DVDDecrypter, but in those rare cases where it doesn't work, I use DVDShink. They're both great programs....Originally Posted by mattyboy
Backing up files
By didikai in forum Newbie / General discussionsReplies: 19Last Post: 3rd Nov 2011, 09:17 -
Are the Jason Bourne books worth a read? I like the movies so far....
By yoda313 in forum Off topicReplies: 10Last Post: 11th Aug 2011, 18:25 -
Backing up a DVD
By kschwi in forum DVD RippingReplies: 19Last Post: 29th Nov 2009, 10:15 -
backing up footage
By JJJewel in forum Video ConversionReplies: 5Last Post: 25th Oct 2009, 08:26 -
Bourne Supremacy; Interactual Player software included and unable to backup
By videobruce in forum DVD RippingReplies: 9Last Post: 28th Dec 2007, 11:39
