originally from:
http://www.techolio.com/forums/phpBB2/viewtopic.php?t=476
and the files are at: http://www.ss3f.com/ilo/
Official ILO site: http://www.ilohelp.com/Here's the steps for anyone that wants to try. I AM NOT RESPONSIBLE IF YOU BREAK YOUR UNIT!!!
3 Hour Mode:
1 - Search for bytes: 00 00 00 01 00 00 00 03 00 00 00 1B
2 - Change 1B to 1F
3 - Search for bytes: 00 00 00 07 00 1F FC 00 at very beginning of ROM
4 - add 4 to first byte before 00 00 00 07 (in Rom 1097 it would go from 1C to 20).
5 - Search for first occurance of bytes 4B 45 59 30 43 50 52 4D
6 - add 4 to first byte before 4B 45 59 30 43 50 52 4D (in Rom 1097 it would go from 35 to 39).
Remove Macrovision:
1 - Search for bytes: 55 53 00 00 00 00 00 01 00 00 00 00
2 - Change last 00 to 01
3 - Search for bytes: 00 00 00 06 00 1F F8 00
4 - add 1 to first byte before 00 00 00 06 (in Rom 1097 it would go from FE to FF).
5 - Search for the first occurance of bytes 4B 45 69 30 43 50 52 4D
6 - add 1 to first byte before 4B 45 59 30 43 50 52 4D (in Rom 1097 it would go from 35 to 36 or if you have already applied the 3 Hr. patch it would go from 39 to 3A).
Burn to CD, insert, reboot ILO and there ya go!!!! Merry Christmas!!!!
Hope this helps some of you ILO users !!!!
Results 1 to 30 of 45
Now if only someone would supply the 1097 firmware to be hacked.
If you upgraded to the 1095, you can NOT flash the hacked 1095 firmware.
Why?Originally Posted by handyguyWant my help? Ask here! (not via PM!)
I just flashed mine with the hacked 1095 and can confirm I now have a 3 hr mode!! Have not tried the macrovision test yet.
There's a 1097 hacked 3hr and macrovision at the site now.
1097 Hacked
Filename: WMEA1097.E20
Use at your own risk.
Hacked to include 3-hour mode and disable Macrovision -
Which version should I try? I have already done the 1095 (non hacked) firmware.
Has anyone tried this an it works? -
@telemike: you'll need the 1097 hacked firmware, then. I updated mine earlier, and it seems to work flawlessly.
Same here just updated mine and it works like a charm.Originally Posted by Jrny2IL
No jitter or other odd issues in 3-hour mode?
update went flawless. Is MV off all the time? i did not see a menu item for mv. i did see the LP mode!
The MV is off in firmware, it does not add more menu options.
http://dictionary.reference.com/search?q=jitter
To make small quick jumpy movements. The pictures on the wall jitter whenever a truck drives by.
Usually up-and-down jitter on some LiteOn units once hacked. Does this do it too?Want my help? Ask here! (not via PM!)
I don't have the Ilo recorder so I can't answer your question.Originally Posted by lordsmurf
I know the dictionary definition of jitter. I just wanted to know exactly what it means in terms of video, and what causes it. Field order wrong? 1 pixel vertical shaking on sharp horizontal edges because of interlace? From your description it doesn't sound like either of those. -
This was a phenomena also seen in some old DC cards. With those, it was a dropped frame, and then the unit was supposedly playing back field order correctly, but flipped. Something along those lines. Several people have mentioned this, and this topic was discussed in depth on the LiteOn forums when they existed.
Easy to check. Record one of the news channels with text scrolling horz. Its a binary item. Will or wont. Also good to check lipsync.
If this messes up can you reload a "non-fixed copy"? -
junkmalle;
When I had jitter on my LiteOn 5001 it looked like a one pixel vertical movement, up a line then back down, at about 4 per second, but it wasn't rhythmic, it seemed to stutter a bit.Proud Member of the Unofficial LiteOn/iLO Beta Testers Club. -
Here's a sample of the LiteOn 5001 jitter:
http://www.digitalfaq.com/downloads/liteon-jitter.mpg
(1.45MB ... right click, save as to your hard drive)Want my help? Ask here! (not via PM!)
Just did the 97+extra patch. Not bad. 3 hour is 1/2 screen like EP but more bits.
Thanks for the sample Smurf. It looks like, every now and then, a field was dropped and the previous field was duplicated to fill in. When a bottom field is dropped the picture jumps down a line, when a top field is dropped it jumps up a line. So basically, it's dropping fields (about 1 in 7?) rather than frames. Interesting.Originally Posted by lordsmurf
Supposedly, it's more like one frame/field is dropped, then the signal goes batty after that. It usually straightens itself out again after a while.
I upgraded my LiteOn 5001 with new 1176 firmware(LNEA1176.DSU.upd.once). Then I tried to load the hacked 1176 and it would not load.
Now I found the solution:
1. Download the 1176 system file from http://www.liteonit.com/DC/english/images/zip/FW_5001_5006/LNEA1176.DSU.0101.014x.rar
2. Apply the above hacks. (Notice:the values will be different, but rules are the same.) This hacked file will load and add macrovision and LP. -
Not real helpful. Any way to provide a final file? Or a list of the values?Originally Posted by cchang
And how does it handle the infamous 5001 jitter?Want my help? Ask here! (not via PM!)
Just noticed the file from the link I gave had been changed. The newer version does not work. The older version I downloaded last month did work. I can e-mail you the final files, if you want. Just let me know.Originally Posted by lordsmurf
edit: The current version does work. You just have to load the unhacked firmware first before loading the hacked version. -
What does the Macrovision hack actually achieve when applied to this unit? For example, will it allow recording from another DVD player, or from a VHS VCR? I have a lot of old VHS tapes I'd like to put on DVD for personal use.
Also, how would it compare to a hacked DVD player, like my Apex AD1500? -
It turns off MV... not that complicated.
I understand that it turns of MV!
What I'm asking is does it affect the incoming signal, the outgoing one, or both?
Ilo DVDR04
By 2003 Hayabusa in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2010, 15:48 -
Lg BD370 Hacks
By lonemonkey in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Mar 2010, 19:40 -
Ilo DVDR04 replacement drive
By emyly7 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Aug 2009, 04:12 -
Question about hacks
By Asmodee in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Jan 2008, 13:36 -
ILo dvd recorder not cooperating
By jhayes in forum DVD & Blu-ray RecordersReplies: 9Last Post: 9th Dec 2007, 11:06
