Ive discovered BIG problems with DivX 5.2.1
***DO NOT ENABLE DIVXs BUILT IN MPEG4 DECODER***
at least not if youre encoding anime to dvd anyway, because disabling this fixed ALL my problems, i didnt get any more "misplaced pixelblocks" round fast scene switches...
also, if that doesnt help try to disable post-proc, because it didnt make my source look better anyway so i disabled it...
btw, i know i shouldnt be shouting this to the world, someone should probably investigate this further.
my setup:
catalyst 12, 512mb ram, 2,6ghz
tmpgenc (rel 2004), divx 5.2.1
tmpg settings:
fps 23,976 with 3:2 pulldown on playback (so its 29fps)
CBR/VBR encoding didnt matter, blocks appeared on both encoding modes but i DID use hi quality encoding (highest motion search, 10bits precision and average 8000 kbit/s)
hope this helps you ppl with problems
Did you try DROPPING that 8000kbs to something like 4000-5000 with a max of say 5500 to 6000.....and drop that motion search down a notch or two....christ its only an animation...I'd go as low as 3500 (or less) with a max of 5500 or a CBR of 3500-4500...DO NOT BE FOOLED BY BIG NUMBERS (whichyou think are better).
Panasonic ES35V. Ive joined the masses. NO READ ERR Any new info on a fix??
By DAVE440 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 21st Feb 2012, 19:10 -
Complex Anime ripping question. Please read. TYVM! ^_^
By Dratheus in forum Newbie / General discussionsReplies: 2Last Post: 5th Aug 2009, 02:52 -
How to read/extract info from ifo file
By cd090580 in forum ProgrammingReplies: 6Last Post: 15th Feb 2009, 23:42 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31 -
Program to read the DVD Header Info?
By alsnchns in forum ProgrammingReplies: 3Last Post: 4th Jul 2008, 11:51
