...then is that writer better off with +R media than it is for -R media? Anybody have experience with this that they'd like to share?
I would have to say "no".
That only affects how it interacts with DVD+R or DVD+R DL media.
It would have zero effect on the DVD-R media.Want my help? Ask here! (not via PM!)
I was curious because drives you cannot bitset like my pioneer 108 are supposedly better off with -R while drives that you can bitset like NEC and LiteOn are supposedly better off with +R media. I've never bitset and only use -R media, but if DVD-ROM turns out to be more compatible, then I'd like to look into it. thx
I had a NEC ND1300A 4x multiformat burner and it worked most excellent with DVD-R but I (for the most part) only used MADE IN JAPAN Taiyo Yuden or Maxell DVD-R discs.
Of course this burner did not do bitsetting by default but I think there are hacked firmwares for it (not sure) that allow that for +R media.
I only ever used the official firmwares on it.
I only gave it up because I bought a new computer that came with an 8X multiformat burner.
Girlfriend dumped water on the old on though I'm sure the NEC DVD burner still works ... the comptuer however does not
My point is I'm not sure if a multiformat burner with +R bitsetting capabilites has lower quality DVD-R burning. I just don't see any connection to suggest that.
DVD-R is generally better than DVD+R with bitsetting to DVD-ROM anyways though I can see the concern for DVD-ROM bitsetting when it comes to DVD +R DL discs.
If you are talking about quality, different burners (manufactures) often "prefer" one type of media - in regards to quality/speed.
For example, Pioneer drives are known to favor -R media (no supprise, since pioneer was behind the devolopement of the -R format).
BenQ (Phillipls) drives seem to prefer +R media (again, no supprise since phillipls was a backer/devoper of the +RW alliance).
My NEC 3500A drive seems to do better with -R media, though only by a small margine.
So the manufacturer of the drive (and chipset in the drive) often favor a type of media. Firmware can also affect the quality and compatability discs.
As far as "compatability" - as in stand alone players - it seems to be the consensus that a +R/RW disc bitset to -ROM is at least as compatable as the -R format. I can say that I have never heard of an instance where bitsetting a +R/RW/DL disc to -ROM has had a negative impact.
In addittion to videohelp.com, www.cdfreaks.com and www.cdrinfo.com have quite a bit of info about bitsetting. (Chech the forums there too!)Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Your Pioneer DVR-108 can bitset if you use the Piodata firmware. Piodata drives are the same hardware with a Pioneer supplied firmware that automatically bitsets.Originally Posted by HatchetMan
DVDFab defaults to second drive as target
By audax in forum Authoring (DVD)Replies: 1Last Post: 22nd Nov 2009, 00:44 -
Replace dvd drive with dvd-rom drive.
By jtrapat1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2008, 11:33 -
New DVD ROM drive, works but PC warns on boot up
By LWC in forum ComputerReplies: 15Last Post: 24th Dec 2008, 18:19 -
Help on Choosing a DVD-Rom Drive
By scustalow in forum DVD RippingReplies: 1Last Post: 13th Jun 2007, 12:04 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 08:55
