I have several short video clips I took using my Canon S1 Digital Camera. I took them at the 640x480 resolution (though I'm not sure that should have a bearing on this problem one way or the other).
Anyway, when I download movie clips from my digital camera to my computer, they have an .avi extension. So I figured I should be able to use TMPGEnc to convert them to .m2v and .wav files just like I have been able to do with other AVI files. But whenever I try to select one of these files, I get an error message that says "can not open or unsupported". What gives? Do I need to do something else to the files before TMPGEnc will like them? Any ideas on how to troubleshoot this would be much appreciated, as I have quite a few long clips on there I want to put on a DVD.
Thanks in advance for your help.
https://www.videohelp.com/tmpgenc.htm#problems might be able to help.
If in doubt, Google it. -
Quicktime for a guess...you should have a CD with your camera with QT (or whatever avi format they are saved in) ..also check the framerate.
http://www.afterdawn.com/software/video_software/video_encoders/qtreader_for_tmpgenc.cfmOriginally Posted by nikkoforeverYou are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
I just got my Canon S60 yesterday. My incomplete search for MJPEG and Quicktime editing tools for the Canon movies has led me to
TMPGENC with
- PicVideo http://www.jpg.com/picvideomjpeg.htm
or
- Morgan-Multimedia http://www.morgan-multimedia.com/technicalsV3.htm
or
Quicktime Reader plug-in for TMPGEnc
or
Windows Media Encoder 9 + Quicktime
install QuickTime Pro or QuickTime Alternative
http://www.afterdawn.com/software/video_software/video_players/quicktime_alternative.cfm
and then convert the .MOV files to .WMV using Windows Media Encoder 9
http://www.microsoft.com/windows/windowsmedia/9series/encoder/default.aspx
Another lead
RAD Video tools.
http://www.radgametools.com/bnkdown.htm
Maybe you can help me finish this project.
Converting MOV files from Point and Shoot Camera
By thomasj in forum Video ConversionReplies: 25Last Post: 24th Mar 2010, 05:17 -
Problem with converting MOV files from iMovie / Camera
By pred02 in forum Video ConversionReplies: 1Last Post: 23rd Sep 2009, 02:25 -
What to do with large AVI video files taken on my digital camera?
By scormodo in forum Newbie / General discussionsReplies: 9Last Post: 30th Aug 2009, 11:13 -
Combing in AVI files when transfered from camera to PC
By ChuckvB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 25th May 2009, 07:03 -
Anyone sucessfully played .avi files from a Canon camera on a DVD player?
By micallen in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Nov 2007, 14:51
