Well I downloaded the trail of 1Click DVD Copy and I have to say that I was very impressed. I ripped a DVD-9 to a DVD-5 at 50% Compression, the ripping time was excellent topping out at about 10 mineutes lower than the other ones I have used ( CloneDVD, DVDShrink, DVD Decryptor, and DVD X Copy Platinum ). One thing that was kind of anoyying was the standalone burn engine that the 1Click DVD Copy used, but it was all automatic so it did the job. When I played the Original on a Mitsubishi Projection 65" i took note of the quality, black level ,and frame overlay. At that point the door rang, so I hit Disk 2 on the dvd player and ran up stairs. When I came back I hit play. I sat there for a minuete and thought the quality was to crisp, the dvd player probably had not loaded the burned disk and was still playing the original. I got up and walked over to the dvd player, it said Disk 2, I opened the tray and sure enough it was playing the burned copy. I replayed it and got really close to the TV, I had a hard telling the differences bewteen the original and toasted one.
It is a free trial software so you can burn 3 complete burns with it. I suggest you try it out, compare it to the other softwares.
Pro:
Unbeleavable Quality
Quick Ripping
Truley One click operation
DVD-R DL, plus options to control if you want menu or the whole thing
Cons:
No advanced view
Seperate Burner engine
Other wise its perfect
If you live in a country that alows copying of Comyrightet Material that the you can use DVD43 and software that removes copyrights
***IF the content Below seem unfit for this forum please edit from here below***
The Disscusion of Wares and Crack or any illegal activity is prohibited on this site strictly. I you have any questions of manipulation of this software contact me but post not of it on this forum Link removed
You are in breach of the forum rules and are being issued with a formal warning. "Manipulation" of trialware to bypass usage controls amounts to cracking, which is warez. No Warez!
/ Moderator Capmaster
Closed Thread
Results 1 to 1 of 1
Acer Aspire One D255 Netbook - a mini review
By vhelp in forum ComputerReplies: 8Last Post: 10th Dec 2010, 22:55 -
Asus EPC900HA NetBook Mini Review
By redwudz in forum ComputerReplies: 19Last Post: 13th Jun 2009, 00:24 -
What is a good price to copy Mini DVDs to DVD-5?
By Des in forum Newbie / General discussionsReplies: 5Last Post: 3rd Dec 2008, 12:54 -
Mini Review - Elecard Converter Studio AVCHD Edition
By Soopafresh in forum Video ConversionReplies: 6Last Post: 5th Feb 2008, 11:38 -
1Click DVD Copy Pro + DVD43
By subyroo in forum DVD RippingReplies: 2Last Post: 6th Jul 2007, 09:29
