I'm trying to understand DVDRebuilder. So far, I can say quality is very good, better than transcoders for long movies and series' DVDs. I'm trying to backup the first season of Smallville. As long as I have noticed, this DVD is hard telecined, ie, it's interlaced but has FILM pattern (DVD2AVI tells it is NTSC, not FILM). I'd like to do a IVTC by adding some lines in avs scripts (telecide, decimate...). Now, I wanna know how can I tell to DVDRebuilder that I converted fps from 29.97 to 23.976 and that I want a pulldown to telecine it again.
I've done that to improve quality.
Reading rebuilder.inf file, i've noticed interessing things like pulldown = 0, that I think I'd have to change to 1. What about frame_rate_code = 1? What do I have to do with it?
Thanks in advance.
haven't worked w/ telecine much...
you might try the Doom9 DVDRebuilder forum:
http://forum.doom9.org/forumdisplay.php?s=&forumid=75 -
I've just visited that forum, but I can post 5 days after my register.
Thanks.
Merry Christmas. -
if the source is NTSC - as what you say ... what you are trying to do is ruining quality, not improving it ....
doing ITVC to a non film source is a total waste of time and destroys the quality ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
and unless you used some very expensive tools (to interpolate) - it will not flow smoothly either ....
The point is that DVD is telecined, but not by a pulldown process. It was hard telecined, ie, frames (fields) were inserted to convert from film (23.976) to NTSC (29.97) standard. My idea is doind a IVTC (by Avisynth plugins), converting at 23.976 fps and doing a 3:2 pulldown on it. So, I reduce the number of frames to be encoded and quality becomes better. I've done this and I can tell you that the quality is really better. The problem is DVDRebuilder "don't know" I did this and video and audio became out of sync.Originally Posted by BJ_M
I hope you understand me.
Does dvdrebuilder use multi cores?
By the_man_one in forum Authoring (DVD)Replies: 4Last Post: 16th Jul 2010, 00:25 -
DVDRebuilder Free/Pro 16:9 crop question
By ecc in forum DVD RippingReplies: 5Last Post: 29th Apr 2009, 11:05 -
No audio tracks (DVDRebuilder)
By stiltman in forum DVD RippingReplies: 3Last Post: 11th Nov 2008, 22:45 -
DVDRebuilder
By santino_avi in forum DVD RippingReplies: 5Last Post: 20th Jan 2008, 15:03 -
Please suggest which is better DVDShrink or DVDRebuilder?
By leinan in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2007, 21:00
