I can make a vcd to play a my bitmap photos as a movie. Or as a slide show i control (forwards backwards etc). But i cannot do it so they both play on a vcd. I use WINON cd to make both but you cannot put them onto the same disk. Any ideas. Thanks
get Video Capturix...it will let you turn bitmaps into avi files very easily...and it is shareware.
Philips Video 2.0 Toolkit will let you do both and also create menus so you can choose which to play. You can also add audio tracks to your bitmap slide show for music, narration or both. It's very easy to use and it's free.
RF -
spaceman1,
It is very easy to put two different pfojects on one CD witn WinOnCD.
What you have to do:
1. Start WinOnCD and choos new Video CD Extended Editor.
2. Insert Menu as the first play item. Create Two selection items on that menu.
3. Insert two Conteiners. Point from the main menu Selection 1 --> Conteiner 1
Selection 2 --> Conteiner 2.
4. Then, when you double-click Conteiner 1, you will go inside it. You can author VCD, Slide Show, whatever you want inside Conteiner 1.
5. When you exit Conteiner 1, double click on Conteiner 2. You'll get inside Conteiner 2. You can author whatever you want here.
I've done this and it worked well.
Cheers.
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 03:18 -
Picasa Slideshow movie can't convert to DVD
By mew1033 in forum Authoring (DVD)Replies: 2Last Post: 13th Mar 2012, 02:32 -
Hollywood Movie DVD vs Slideshow DVD
By c9dxmo in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2010, 08:08 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
Photo DVD slideshow movie
By j4mes_bond25 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2008, 05:58
