G02,F02,R01 etc etc.What do they actually tell you about a disc? What is the difference between R03 and R04 for example,is one just newer than the other?
I tried to find it on the forum,but couldnt see anything regarding that.Is that code important besides the name of the actual disc-maker? If a disc was Ricoh-made,would it matter what that code was?
I was using DVD Identifier to check the different brands of discs that i have(and no surprise a lot of them are CMC-made,although having said that,the Philips-CMC's have been ok) but i just wanted to know what those codes mean,and if they are relevant to quality.
I just bought some Memorex +r's yesterday from Wal-Mart,and they turned out to be Prodisc R03 003(Made in Taiwan btw) which,from reading posts here,is better than the Hong Kong stuff that appears.
Also,i would like to know if there is a program like DVD Identifier that does the same for CD-r's
cheers,and Merry Xmas
Results 1 to 1 of 1
Audio Not Clear in AVI
By abdul_sma in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2010, 10:59 -
Why does this video look so clear?
By brassplyer in forum Video Streaming DownloadingReplies: 4Last Post: 16th Jun 2009, 22:42 -
UV vs Clear Glass Filters
By thurnau in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2009, 13:17 -
Is Clear QAM common?
By Mormegil in forum DVB / IPTVReplies: 11Last Post: 26th Oct 2007, 15:13 -
16bit Audio not Clear :(
By ozab in forum Capturing and VCRReplies: 0Last Post: 31st Jul 2007, 11:51
