I recently bought a DVR (Panasonic) and am recording to both a HDD and DVD-RAM. In my computer, I have a DVD/CD drive that will play the DVD-RAM video. I would like to copy the RAM video onto my computer hard drive, and then edit it and then burn it to a DVD. However, it format of the RAM video has an extension that I am not familiar with (I'm at work and don't have the RAM in front of me, but I seem to recall it being a .VRO extension). How can I convert the video to either mpeg or avi?
TMPGEnc DVD Author can do this for you. Use the "Add DVD Video" function, and TDA will recognize what is on your DVD-RAM and convert to MPG-2 and download to your HDD. You can then use TDA to edit, author and burn. Or you can use the MPG file that TDA created, and use it in another authoring program. TDA has a 30 day trial and I highly recommend trying this method.Originally Posted by cr8zycatThat's my opinion, and if you don't like it, I'll change it.
"http://www.google.com/search?sourceid=n ... RO+to+mpeg"
Who needs them? We have tons & tons of topics on this here already that cover every possible aspect
Simple
Copy the .vro file to your computer and rename the extention to .mpg.
Now you can import to your favorite video editing program to edit the movie as you desire.
Once finished or if you didnt need to edit it, import the .mpg file into your favorite dvd authoring program and burn away.
If you want to create a menu or add chapter use TMPGEnc DVD Author to import the .mpg file, create chapter stops and use its templates to create a menu or be creative and create your own.
Hope this helps
Happy Holidays!
Editing Panasonic Burner DVD-RAM VRO Video In Computer
By Teshia in forum User guidesReplies: 47Last Post: 18th Feb 2013, 08:06 -
Block errors in video extracted from DVD-RAM disc
By kosdi07 in forum DVD RippingReplies: 0Last Post: 2nd Mar 2012, 15:45 -
Complete novice, transfer DVD-RAM video to PC
By Mount1003 in forum Newbie / General discussionsReplies: 18Last Post: 30th Dec 2009, 18:57 -
Playing DVD-RAM Video Disk On PC
By Rayvyn007 in forum Software PlayingReplies: 2Last Post: 23rd Jan 2008, 13:01 -
How do I transfer Video from PC to DVD Recorder using a RAM Disk
By barry_w2 in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 13:14
