[edit]It works! Just don't delete entire blocks and it will be alright [/edit]
Hi people,
I'm new here so I hope I post this right
The problem comes down to this:
When I want to change a menu (i.e. removing button overlays) and want to import everything in DVDShrink when finished, i get erros saying stuff like "Could not load file Invalid data in file VTS_...vob ". I going completly nuts 'cause I tried everything. Here is what i tried:
1. Get DVD on HD by DVDEncrypter
2. Opening MenuEdit 2.3.1 (or DVDRemake) and begin hiding surthen menu buttons (extra languages etc which I want to delete later on with DVDShrink)
3. When saving and exiting the program rewrites a couple of vobs and finishes
4. I’m opening DVDShrink v3.2, open files, choose folder the movie is put in, THE error
Also when I used DVDRemake it gives the same error. Something I must say is that every time I also delete blocks from other menu’s. I mean, on the dvd there are multiple menu’s in different languages. All other then the English one, I don’t need (saves me space). With the dvd I tried, all the menu’s were in the same VTS, the main movie VTS.
Tonight I’m going to try if it helps when I don’t delete complete blocks in the VTS but only disable menu buttons. If it helps…I’ll edit my post. But for now, I hope somebody knows the answer.
Cheers!
p.s. don’t mind any typos, I’m dutch
