I tried to add a mpeg file but it came up with the following errors:
"The video resolution 512x288 cannot be used for a standard DVD.
For a standard DVD you can only use the following resolutions:
352x240 352x480 704x480 720x480 pixels (NTSC format only)
352x288 352x576 704x576 720x576 pixels (PAL format only)"
"The video framerate 23.976 fps cannot be used for a standard DVD.
You can only use the following framerate for a standard DVD:
29.97 fps (NTSC format only)
25 fps (PAL format only)"
"The video sequence header is incorrect.
A video sequence header is necessary for every GOP in a standard DVD."
Any ideas how to fix this.
I reiterate that the file i was trying to add is a .mpg file........
Thanks in advanced.
TMPGEnc would be my tool of choice to fix this, but you could use any MPEG encoder.
Re-encode using one of those resolutions mentioned.Originally Posted by YinHoNg
When you re-encode (because of the first issue), set the frame rate to 23.976fps (internally 29.976fps) but set the encode mode to "3:2 pulldown on playback".Originally Posted by YinHoNg
When you re-encode (because of the first two issues), Make sure you set the "output interval of sequence header" to 1, and the "Max number of frames in a GOP" to 18.Originally Posted by YinHoNg
So to summarise, I'd use TMPGEnc with the DVD (NTSC) template, then load the unlock template, then change the frame size to a DVD-compliant size as described in 1), then change the fps and encode mode as described in 2), then check the GOP settings - using this template, they should already be set to what I described in 3). You'll also need to set the bitrate to an appropriate value.Originally Posted by YinHoNgIf in doubt, Google it.
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
Adding chapters to DVD project in TMPGENC DVD Author
By robertazimmerman in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 11:09 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 20:53 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
