My pioneer DV-530 player suddenly give " no disc" error today but DVD plays fine. anyone know how to make it play VCD and SVCD again? pls help.
also i just bought ALBA DVD566, is there any hack to make it play vcd/svcd as well? in case you guys don't know this model, it's the one sold at argos uk
package with alba home cinema audio system. here is the link.
http://www.argos.co.uk/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-...clickfrom=name
thank you in advance
about that ALBA DVD566 i decided to take it back to argos and change it for philips DVP520 at the same price £49.99 but i was given DVP630 instead, how lucky i was this player can play divx. the price is £79.99
but i just pay £49.99
so, about my pioneer DV-530 anybody have the answer? i have try every trick posibble in the manual but to no avail. -
Sounds like your player is dying. I had a norcent dp300 do the same thing. It will play factory pressed as well as burned + and - format dvds but will not play anything on cd media. Just happened all at once. I don't think you will be able to do much short of getting it repaired and it would probably be cheaper to just get a new one.
Donadagohvi (Cherokee for "Until we meet again") -
DVD players that play VCD/SVCD use a different laser for those discs than to play DVDs. Your player probably has a problem with that laser and needs repair. Given how cheap players are today, it's probably cheaper to just buy a new player than to repair this. Newer players probably have features your player lacks.
Hard Drive upgrade for Pioneer DVR-530/630H
By Hkan in forum DVD & Blu-ray RecordersReplies: 55Last Post: 22nd Aug 2012, 02:07 -
Pioneer BDR 205 won't play BDMV video discs
By kurbads in forum Blu-ray RippingReplies: 4Last Post: 30th Jan 2012, 04:39 -
Pioneer DV-260 won't open
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Sep 2009, 22:09 -
Pioneer 510-H Won't Power Up
By groberson in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st May 2009, 01:11 -
Pioneer DVR-530 disc tray doesn't open
By Alex_x in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Sep 2008, 17:39
