I want to know what settings you use when rippin DVDs to SVCD. Here are the setting I use
Output Frame Rate 25
Video Bit Rate 1700 to 2000 denpending on the length of the video
Motion Quality Good
Resoluation 640x480
Volume 5 To 6
I use 1click DVD To VCD to make my SVCD it was just a test. I try to keep it under 1400mb to only have two cdrs. What freeware program do you guys use to make SVCDs. Also does anybody know of any good freeware video ripper for mpg avi asf and such I want to rip a video into 2 files.
Well, one setting I don't use(ed) is the resolution! 640*480 is no good for anything. 480*480/576 (NTSC/PAL) is the only valid SVCD resolution. 352*480/576 is an alternative, CVD, that most SVCD players will handle too, and that has the advantage of being upwards compatible with DVD.
Never used anything with "1click" in the name either
Take a look under tools for other video conversion tools, and under Convert for guides on how to use them.
/Mats -
I'm not exactly sure which tool you are using but I know that if you plan on playing those SVCD's at that resolution you probably can only do so on the computer. NTSC should be 480 x 480 and PAL should be 480 x 576. More information is here. https://www.videohelp.com/svcd
Last time I made an SVCD, I was using DVD2SVCD, loved it. Mostly everything was already set up for you, except the audio I think I had to change it to 224 kbps (sp?) and 44100 Hz. Hope this helps.[/url]When man discovered milk came from cows, what did he THINK he was doing?
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
n00b saving in Ulead for svcds and dvds myspace
By dsound in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2008, 12:40 -
2.5.3300 SVCDs getting recoded
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 15th Oct 2007, 21:44 -
which setting should i use
By fruitpassion in forum Video ConversionReplies: 4Last Post: 23rd Aug 2007, 19:58 -
Winavi v8 SVCDs jerking with SVCD2DVD
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 13th Jun 2007, 16:02
