I just started using DVD-Lab Pro to author. Up until now, I've been using TMPGEnc DVD Author. Great program, but no subtitles and no delayed menu buttons... Anyway, I know that I can fit MPG's which are 4200MB when using TDA (leaving enough room for menus). How big a file can I instert into a DVD-Lab Pro?
eMARTY69
It depends how much space your menus take up. Bottom right corner is an indicator that shows you how much space your assets are consuming. If you don't go nuts making huge motion menus, there is no reason why you cant keep encoding to that size.
Read my blog here.
Vegas to DVD Lab Pro motion menu issues
By outerspacerace in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2008, 21:28 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 08:32 -
Delayed Links, Motion Menu and DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 14Last Post: 30th Apr 2008, 02:33 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 23:53
