I have 2 separate mpg files files that I need to combine and make one mpg file can someone tell me what is the best and quickest software to do that?
Also I would also like to convert this one combined mpg file to dvd afterwards. Could I also get some help with the software needed to do this also?
Thanks to anyone who took the time to read and/or respond to my post.
Appreciated
If your MPEG file is DVD compatible, then just put both of them into your authoring program (TMPGEnc DVD Author recommended) and they will play seamlessly, one after the other. Combining MPEG files before authoring can result in out of sync audio, depending on your method. Combining them in the authoring stage is usually the better method.
You can also use TMPGEnc encoder to add video files together, but the authoring method works great if you are going to convert to DVD.
2 srt files to combine - how?
By jlrm365 in forum SubtitleReplies: 7Last Post: 17th Apr 2016, 07:15 -
Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
By buzzworm in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2012, 16:22 -
Need to combine .mpg files to one (What to use)
By neworldman in forum EditingReplies: 5Last Post: 26th Jan 2011, 17:23 -
How would I combine 2 avi files into one?
By Variable in forum Newbie / General discussionsReplies: 7Last Post: 27th Sep 2010, 16:50 -
trying to combine quicktime files
By dwayne00 in forum Newbie / General discussionsReplies: 3Last Post: 4th Apr 2008, 19:09
