Whenever I go to delete something, it doesnt move to the Recycle Bin like it should, it just leaves permanetely. How do I make it so it does go to the Recycle Bin? And when I right-click the Recycle Bin, the option to move it to "NOT move to Recycle Bin" is unchecked. Any help is appreciated. Thanks
Results 1 to 15 of 15
"The statement below is True,
The statement above is False" -
Does that happen with very large files? If so, that's normal. Above a certain size it won't hold it in the RECYCLER folder. It depends on your bin settings.Originally Posted by lowlow42
Oh no, any file. Little Text files, mp3 files, big files, everything.
Right click the recycle bin and uncheck the do not move to recycle bin option.
Still not working.And when I right-click the Recycle Bin, the option to move it to "NOT move to Recycle Bin" is unchecked."The statement below is True,
What size is the file?
If it is over 100 megabytes it usually is too big for the recycle bin in which case it is automatically deleted. -
Does that happen with very large files? If so, that's normal. Above a certain size it won't hold it in the RECYCLER folder. It depends on your bin settings.Oh no, any file. Little Text files, mp3 files, big files, everything."The statement below is True,
I had this happen once, all I did was tick the 'Do no move files to the Recycle Bin', apply it, then untick the option again and apply it. This was enough to reset the values and the bin started working again.
Worth a try if you have not already tried it .. -
Yeah, I tried that and unfortunately that did not work either. But thanks for the advice.
Another thing to check is the permissions on the 'Recycler' directory, they may have become restricted.
'Administrator' and 'System' should have fully access (everything ticked). -
If I get in "My Computer", where is the Recycle Bin directory located? I will check under safe mode, as Administrator.
I dont know why it is doing this all of a sudden, because it used to act normal. Another thing that has been acting weird lately, is how my icons keep changing views (Tiles to Lists, Icons to Details, etc). I dont think its viruses or anything, because I do scans frequently and keep my computer updated."The statement below is True,
Sounds ominous!
The Recycler directory will be hidden, so on an explorer window you will need to select 'Tools' -> 'Folder Options' -> 'View' and click the 'Show hidden files & folders' setting, to see it. -
Okay, I will try that this evening. Thanks.
I'm sorry, I never posted to say how it went. Unfortunately I still have my problem. And already I've accidently permanetly deleted files which I actually needed. One thing I did notice however, is when I delete something from my 2nd hard drive (WHICH HAS NO Operating System installed), it goes to the Recycle Bin, when before it never did before, and it would always just delete permanetely.
Recycle Trash bin
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 26th Apr 2009, 13:11 -
Where to Recycle CD's
By Nitro89 in forum Off topicReplies: 7Last Post: 1st Aug 2008, 15:56 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 07:16 -
Recycling Bin
By Nitro89 in forum ComputerReplies: 6Last Post: 20th Feb 2008, 08:02 -
recycle bin errors
By piano632 in forum ComputerReplies: 11Last Post: 29th May 2007, 09:33
