Hi,
A while ago (and i'm talking bout 2 months) I recoded a divx source to mpeg2 using TMPGEnc. The source was animation and the latest DivX changelogs (since DivX 5.2) say they should improve quality even more for anime (no my source isnt pokemon or dball z or whatever commercial crap). So I decided to recode my source to mpeg2 to benefit from these improvements, i needed to do this anyway because i wanted to make a proper DVD menu.
Anyway, to get to the point, I installed the *latest* TMPGEnc (the one released this year) and DivX 5.2.1 so i could recode the source to mpeg2.
Unfortunately however, i noticed artefacts appear almost every scene change! I couldnt remember getting those before, so i quickly installed the latest TMPGenc released in *2003*. It didn't help however, so now I'm wondering if it's DivX that is causing the problems?
However, i still have my source and when i watch it using Windows Media Player i can not see any artifacts, so it probably isnt DivX either...
I'm using the exact same TMPGenc settings as before too;
NTSC, 720x480, 4:3, 23,976 (internally 29) with 3:2 pulldown, 10bits, highest motion search, GOP: 1 5 0, and i tried CBR 9050 and 2PassVBR too.
I played around with a couple of them but they didnt make the artifacts dissapear
Does anyone know how this could be happening and how I could fix this?
Thanks, and sorry for making it so long, only i wanted to provide you with the necessary info![]()
Sounds like your source contains artifacts, so unless you are able to filter them out then they will also be in whatever you convert to.
There are many possible reasons why.
Encode the file with VSO's DivXtoDVD and see if the artifacts remain.
It's free. http://www.vso-software.fr/download.htm
It will tell you if the problem is with the source file, or with the encoder. -
no my source is fine, because i dont see any artefacts while i watch it, only the mpeg2 version of the source has artefactsOriginally Posted by celtic_druid
thank you soupafresh, i will try it out right now... -
soupafresh, the program says the file is inaccessible or doesnt have a correct A/V
BUT it wasnt in the list of supported files so i had to select All Files before i could select my source to convert (its .ogm).
Ive been thinking, and i suddenly remembered one noticable difference between last time: im using Omega Radeon Drivers instead of the default catalyst ones, you think that might have something to do with it?
Ill try the catalysts to be on the safe side anyway
Btw, some more info about the artefacts:
* they do not appear every scene change, only fast scene changes
* they look like misplaced "blocks"
if anyone else has any input to this problem whatsoever, please do not hesitate to post !!
**UPDATE** The latest catalyst 4.12s didnt fix my problem
, i still see small block artefacts when theres a fast scene switch (ie a lot of motion).
Okay, problem "solved"
the first of the several files that my source had had these block artefacts already, i just didnt notice them... thanks for all your help tho
and sorry to be bothersome
Removing artifacts
By IsAB in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2011, 10:51 -
H.264 flashing motion artifacts on scene changes
By adramolek in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2010, 22:32 -
x264 artifacts on dark scene
By kartul in forum Video ConversionReplies: 18Last Post: 3rd Nov 2010, 17:14 -
Looking for artifacts
By Caple in forum RestorationReplies: 18Last Post: 1st Oct 2010, 21:27 -
Artifacts in Video
By arturjose in forum Video ConversionReplies: 6Last Post: 17th Feb 2008, 20:03
