I'm trying to convert an AVI into Mpeg(DVD) using TMPGEnc, and the video converts fine, but there's no audio. I've tried changing the priority of the DirectShow thing up and down but either way doesn't solve the problem. I also installed the AC3 Decompressor, but that didn't do it either.
What else do I need to do?
Extract the audio to wav and use that as the audio source for TMPGEnc.
Guide here."Art is making something out of nothing and selling it." - Frank Zappa -
https://www.videohelp.com/play.htm#identify
Identify what type of audio you have. If it's MPEG-1 Layer 3 VBR audio, then do as ZippyP says. If not, post a screenschot from GSpot or AVICodec back here, and we'll go from there.If in doubt, Google it. -
It says that it uses "AC-3 ACM Decompressor".
I was wondering if it was a good idea to convert it to .wav first, because the audio and video might not match up perfectly. -
TMPGEnc Plus cannot re-encode AC3, but what you can do is demux this from the file using Virtualdubmod (open the file, go to streams > stream list, and click demux), then encode just the video part in TMPGEnc (to create a M2V file) and then use your authoring software to join the M2V and the AC3 you demuxed back together.Originally Posted by lazyturboIf in doubt, Google it.
Here's a guide by Baldrick (the site admin.) that explains how to convert your avi w/AC3 to a DVD w/AC3.
Good luck.
Cool, thanks...and this will ensure that there won't be any audio-sync problems?
That can never be ensured. As soon as you separate audio from video, there's a risc that you will get sync issues later on. However, this is easily fixed (once spotted) by adding some silence/cutting a little at the start of the audio.Originally Posted by lazyturbo
/Mats
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 10:27 -
Getting Audio before TMPGEnc?
By chronic777 in forum Authoring (DVD)Replies: 2Last Post: 5th Apr 2009, 08:52 -
TMPGEnc no audio
By jay_lubb in forum Video ConversionReplies: 4Last Post: 23rd Mar 2009, 12:16 -
No audio in TMPGEnc
By jay_lubb in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 03:26 -
TMPGenc and audio file
By JosieB in forum Video ConversionReplies: 10Last Post: 27th May 2007, 05:33
