i just brought a video capture card
everything went soothly when i install the driver or the software
but the thing is i can run the software.
i double click the icon but it didn't respond to me
then i try virtaltub
it says i do not have any capture device??
why???
plz help
1. please change your subject to something that describes your problems instead of just help
2. please tell us more info...what capture card? you computer? os? -
find a program called wrapper and run it, it will install the drivers needed for vdub, do a seach in the forum for wrapper, if for some reason you can't find it I think I have a copy.
Also, make sure your device is functioning, check your device manager to see that your have no ! showing, and make sure your device is listed there. You did not say what kind of card or operating system you are running.
