  1. i was just wondering how I could fix this video... for some reason, its all pixalated from the bottom.... this is how it looks throughout the whole video:
    if you can help, that'd be great!
    and if there is no possible way to fix it, then also please let me know.
    thanks
    The file is corrupt. If so, no.
    Or you're using the wrong codec. If so, maybe.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Check your file with gspot and it will show the codecs.
