Results 1 to 21 of 21
  1. I am trying to follow a guide on using virtualdubmod to output in MPEG2 format. I get up to this point in the guide, and under Video/Compression he has ffdshow video codec listed (see this pic).
    http://img37.exs.cx/img37/6226/MPEG.png
    I've tried installing ffdshow filters and codecs and it either causes virtualdub to crash or ffdshow doesn't appear in this list. How can I make it appear?
    Thanks and sorry for the newbieness
    Kieron
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    maybe i am wrong - but i dont think you can output mpeg2 with virtualdubmod
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    what guide anyway
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    YMPEG can enable MPEG out output from virtualdub or its variants - looks like ffdshow can too.
    If in doubt, Google it.
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    oh - news to me, i dont even have it installed right now ..
    Dec 2004
    Australia
    The lastest build of ffdshow listed on sourceforge has a problem with the installer. Basically it is supposed to use the short path variable for the VIDC entry, but it uses the full path instead.
    To fix it you need to go into your registry and change the entry from program files to progra~1.
    Could also try a newer build as they make use of a VFW wrapper that goes in your system dir, so no more path problems. I was thinking of doing a new compile maybe today as theora and a few other things have been updated.
  7. Thanks Celtic, I changed the path in the registry and that worked.
    Capehorn
    Jun 2004
    Ferrara-Italia
    ok it looks like this question pops up every other week
    Sorry, I had to go see about a girl
  9. You could try avidemux, its basically a vdub clone but supports mpeg2 output via the lavcodec. Its native for linux but has been ported to windows.
  10. Член BJ_M's Avatar
    Jul 2002
    Canada
    what question?
    first time i noted this .
    Dec 2004
    Australia
    Actually there are quite a few posts on VDub, ffmpeg and MPEG2 encoding with VDub in general.
  12. Член BJ_M's Avatar
    Jul 2002
    Canada
    oh -- guess i was referring to ffdshow encoding --
  13. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    This is the 4th or 5th in the last month that I've seen
  14. Член BJ_M's Avatar
    Jul 2002
    Canada
    i dont spend enough time here
  15. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    kieron, you will have to install ffdshow in a directory that has no spaces/only 1 name for instance C:\FFDSHOW. it is a bug in the installer. If you install it to C:\Program Files\FFDSHOW it will NOT work. You STILL will have to mux your audio & Video if you are creating a .mpg though.
    Happy Holidays!
    Rog
    There are many ways to measure success. You just have to find your own yardstick.
    Dec 2004
    Australia
    It will work if you go into your registry and manually change the path as I already covered.
  17. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    Sorry Bout that Celtic, did not see your post. Where is the newer build?
    I've got the 10-12-2004 version
    Later & Happy Holidays!
    Rog
  18. Originally Posted by jimmalenko
    And there's a special price for purchasing YMPEG, but only today!
    http://www.ympeg.com/download.htm
    Dec 2004
    Australia
    10-12-2004? You mean 2004-10-12? Which for me is 12-10-2004.
    Anyway last build I did was 2004-12-23 and can be found here: http://celticdruid.no-ip.com/xvid/ffdshow/
  20. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    cannot download from your site, but was able to get it from doom. Bug is fixed! Rog
