Hi,
what is the best settings in Procoder 2 to convert from Huffyuv to MPEG2 DVD compliant? the source is a slideshow, every pucture has a timing of 4 seconds, the transition is 2 seconds. Is better VBR or CBR?
As I understand it VBR is a techinique to save space. If you have a high motion scene followed by a low motion scene the encoder will 'borrow' bit-rate from the low motion scene to get better quality in the high motion scene. It's a balancing act....
That being said I don't think you'll see any difference between the two in a slide show but, you may see a smaller file size with VBR.
If file size is not an issue just use CBR and the "highest quality" or "mastering" setting.... -
Do the pictures in your slideshow just fade into one another? (dissolve transition)
Or are they more complex?
I suggest the use of a bitrate calculator so you get an idea of how much stuff you can put on your disc at a quality you find acceptable. Then try those figures in Procoder and see if you're pleased, if not tweak em a bit.
@upshot
VBR doesn't borrow. It just allocates a higher bitrate for more complex scenes based upon the settings you've indicated (min/avg/max bitrate).
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 10:51 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
chapters with procoder 3
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 17th Oct 2007, 11:20 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25
