  1. if i have a streaming video that is on my desktop am i able to encode it using tmpegnc so i can burn it to dvd.....or there is any way i can do this.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you have to save a copy to your system first
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Yep BJ_M is correct. Here are some video streaming tools:
    https://www.videohelp.com/tools?s=37#37
    https://www.videohelp.com/tools?s=39#39
    Then determine the properties of the video using gspot or bitrate viewer and look up the guides under the "how To" section on the left <----- to see how to convert them
    Kevin
  4. i can't seem to find the right guide to work with the streaming video. i read through most of them and can't seem to find it....can somebody point me in the right direction where excactly it is .
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    depends what the streaming video is --
    just save it --
    encode it
    the end ..
  6. let's say it's video on demand....i save it to my desk top and encde it...........correct.
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    if it has DRM - you may be out of luck
