I want to use Mpeg4 Modifier to convert my QPEL video that is not compatible with my Philips dvd player. The problem is, everybody talks about this little program and NOBODY tells how to use it. The Tutorial is nowhere to be found. Not even the site of the program has it. How on earth i'm i suppose to know what to do??
Please someone help me![]()
select unpack bitstreams on xvids , and is a simple process, check the box and change the "p" to a "n" in the user data box by clicking edit and resaving the file
Only thing that MPEG4Modifer can do about qpel is tell you if a file uses it or not. Then again I already explained this to you https://www.videohelp.com/forum/viewtopic.php?t=248556&highlight=
Perhaps you should read the reply instead of starting new threads.
Also if you have the userdata tags set to auto it will automatically remove the DivX999b000p tag which is what I would suggest anyway.
Delete Original file with MPEG4 Modifier Commandline?
By rvman in forum Video ConversionReplies: 6Last Post: 28th Jul 2009, 18:55 -
mpeg4 modifier application error
By fundaris in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2008, 08:59 -
Help with MPEG Modifier... Packed Bitstream...
By GangstaRap in forum Newbie / General discussionsReplies: 0Last Post: 24th Dec 2007, 13:14 -
MPEG4 Modifier and GSpot for Mac?
By tzikeh in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Nov 2007, 00:06 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 31st Oct 2007, 00:47
