what is the best and easiest to use with NERO 6 to convert to BUP/VOB/IFO files unless something better thanks
Gee I wish one of us (either you or me) had any clue what the hell you are talking about.
If your mpeg files are dvd compliant then use tmgenc dvd author to author those files and then burn with nero 6 as dvd-video.Check to the left to read more on the basics of authoring.
i have nero 6 my movies mpeg avi but must be bvp/vob or ifo to burn to dvd why only those 3 THANKS TOM
I would have to agree.Originally Posted by hech54
Sounds like he wants to author... maybe.Want my help? Ask here! (not via PM!)
If I comprehend this cryptic message correctly, you've got some sort of video contained in an AVI that's probably an MPEG4 format video stream. If this is true, then you need to recompress into MPEG2 before using some authoring tool, such as the oens previously prescribed. Then, you can burn w/ whatever (Nero or TMPGEnc...i like TMPGEnc coz it takes out all the options that you don't need to see to burn a DVD-VIDEO)Originally Posted by pasmurf999
most common used converters
By alijutt in forum Video ConversionReplies: 0Last Post: 22nd Dec 2011, 20:35 -
Which Codecs or just not should you use with these 3 converters?
By NZBPirates in forum Video ConversionReplies: 4Last Post: 3rd Oct 2010, 14:23 -
Canopus ADVC110 or other converters
By pdx10 in forum Capturing and VCRReplies: 3Last Post: 13th May 2009, 13:35 -
A/D converters
By takenotes in forum Capturing and VCRReplies: 1Last Post: 12th Dec 2008, 10:57 -
all in one converters
By JayLeo in forum Video ConversionReplies: 12Last Post: 3rd Sep 2007, 09:10
