If I wanna fit double min in one CD, do I have to cut both res and bitrate by half?
Res means nothing in terms of how much running time you'll get onto a CD. So all you have to do to get double time is use half the bitrate (audio and video, or keep audio the same and adjust the video by more to compensate). The killer comes when by adjusting your bitrate, you can be forced to adjust your res in order to retain the sameor similar quality. But strictly speaking, the bitrate is the only thing that affects the file size.
If in doubt, Google it.
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
Quick AVIdemux question!
By janlafata in forum EditingReplies: 16Last Post: 17th Mar 2009, 01:19 -
Quick laptop tv out question
By Tidy in forum ComputerReplies: 3Last Post: 28th Jul 2008, 14:42 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 07:21
