That's the problem!
When I use DScaler to preview, the image is perfect. When I try to capture in 720x480, apears a lot of random lines like these. I don't have problem with dropped frames.
Please help me!
Thanks!
Results 1 to 17 of 17
http://leonardovilar.sites.uol.com.br/clapton.jpg
if the screenshot not work press 'reload' -
Your signal is unstable. I've seen the for varying reasons.
Are you using s-video? If so, quit. Use composite for this.
What other devices are being used? VCR? etc?
Some of these can cause this problem, when interacting with a bad tape.
When you answer all this, you may want to PM me with a link to this thread.Want my help? Ask here! (not via PM!)
Honestly ... go for the lazy way out.
If 352x480 works, then just do that.
Since this is coming from VHS source, you have nothing to gain by capturing maximum resolution.
I don't think it's worth the time to figure it out, not in this case, not this time.
It may have something to do with your card, capture software, or combination of the two.Want my help? Ask here! (not via PM!)
Hmm... i'll do some tests!
The problem is that soon I will start capturing some Laserdiscs! What resolution you think is great to do this??? -
It's all about the card you are using!
Yours must be this: https://www.videohelp.com/capturecards.php?CaptureCardRead=81#comments
It seens that your card is a bt8xx based, so I suggest you btwincap drivers and virtualvcr for capturing. The higher you can, the better in your case, for various reasons!
Brazil use PAL M or something, which is very similar to that horror called PAL 60. You are a special case there... (You have to capture 720 x 480 with a PAL framerate...)La Linea by Osvaldo Cavandoli
Yes, it's my card.
I've tried to capture using that drivers and VirtualVCR and other programs also like iuVCR but the results are the same when capturing in 720x480.
Here in Brazil the system is PAL-M, argh!
I think the problem is with my mainboard. Because my old Intel P4 Motherboard died, I need to replace. I've bought ASUS P4V8X which uses VIA chipset.
I want to solute this but I don't know how!
VIA chipset... my nightmare!
The results are the same capturing @ 704x480 (25fps). Also I've tried to capture using DScaler and the things still the same! I think is something related to HD bw. Using the 'poorest' codec settings capturing @ 720x480 I get less lines like these... but I don't have problems with dropped frames!
Did you set DMA on?
Via need some patches for HDsLa Linea by Osvaldo Cavandoli
DMA is enable. I think if it's not, the major problem is dropped frames. And I don't have any troubles with dropped frames, only with this lines. I've found some updates on viaarena.com and updated everything and my Asus motherboard bios also.
Miss you my Intel chipset motherboad!
Nforce is the answer! (AMD supporter...)
Yeap, that the good thing with an "wintel" PCs... They actually work when you buy them compact...
And stay away from VIA! (there are 2 things I hate most: Via chipsets and Princo CDs....)La Linea by Osvaldo Cavandoli
I'll look some Intel motherboard like my old one to buy!
That's the solution! No way!
Btw, thanks !!! -
just deinterlace or encode it to to mpg, those lines are interlace lines.
i deinterlaced that pic
look at the difference
With deinterlace the problem is not solved because some lines appears like a "tremolo" in the video.
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 11:02 -
Horizontal Lines Appear In DVD
By Mark-Leon in forum MacReplies: 33Last Post: 17th Oct 2010, 11:23 -
horizontal lines in mpeg2
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 15th Dec 2008, 18:05 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 20:59 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 13:06
I'd recommended using
