  1. I was just curious if removing timecodes on a captured source would be the same as removing logo's? Or is there a different filter/program that can do this?
    Thanks.
    Apr 2004
    Miskatonic U
    Logo remover would be the best bet. If the source is DV, you can often turn the timecodes off, as they are stored as data, not embedded in the image.
    Read my blog here.
