I am trying to convert an AVI to DVD format using DIKO and the end result is that the audio is out of sync.
Here are the steps that I follow:
1.) Play the AVI using VLC - audio is in sync.
2.) Run DIVFIX to rebuild indexes - audio is in sync.
3.) Run Virtual Dub, Mod and Freeze - all load the AVI without warning and no errors are evident after scanning.
4.) Convert to DVD format using DIKO and the audio is out of sync.
I have a couple of questions:
a.) Is there an additional utility I should be running * before * DIKO to ensure that the audio is in sync?
b.) I use Virtual Dub / Interleaving to delay the audio track. However, I am * guessing * the amount to skew. Is there a correct way to calculate the amount without trying multiple guesses?
Thank you in advance.
Results 1 to 15 of 15
Download VSO's DivXtoDVD program and test your end result for sync problems.
http://www.vso-software.fr/download.htm -
No, although different programs do the audio conversion part differently.
Just trying to rule out the program from the possible list of culprits. -
Here is my update:Originally Posted by Soopafresh
I used ImgTool Classic to create an *.ISO and the audio is synchronized!
It might be my imagination, but I think that the Video image created by DIKO's tools are sharper than DivxToDvd.
DivxToDvd seems to only run 1 pass versus DIKO's 2 and in a lot less time. -
The simple answer is FORGET any ALL IN ONE SOLUTION.
Then read the guides OR Google. -
I am willing to try your suggestion.Originally Posted by monzie
Can you recommend * one specific guide * for a newbie that uses freeware?
I would really appreciate your advice. -
My suggestion is to quit relying on other people's crappy capturing and DIVX encoding. If you do not control 100% of the process, you'll never get 100% successful results 100% of the time.
You're doing what I call a salvage operation. Take what you can and quit worrying about perfection. You never had it to begin with.
You are dealing with a format (AVI codecs) that has no set standards.Want my help? Ask here! (not via PM!)
I totally understand what you are saying and I appreciate that you are being so candid.Originally Posted by lordsmurf
I think that my particular agrevating (sp) factor is that the same DVD's worked on a Pioneer DVD player that we bought * last * Christmas. Since we bought a new Pioneer DVD * recorder * this Christmas, the macroblocks have started to appear.
I feel like my knowlege at this point is one step forward and two back. -
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm might help.
Unfortunately, trial and error is the only way to fix synch problems, aside from buying the DVD (if available) of course
If in doubt, Google it. -
You've confused me.Originally Posted by allanc448
We've gone from talking about converting DIVX to DVD.
And somehow ended up on the DVD player?
I do not see the connection.Want my help? Ask here! (not via PM!)
Yeah we don't expect it to be perfect but audio synch has been done before. So this means it CAN be done. So we're not asking the impossible here. We just need to know what's the best way to do it.
I know I sync the audio and the video perfectly before...just recently it's been acting up. -
My apologies, I have two threads going here with different problems on the same AVI. I got confused between them.Originally Posted by lordsmurf
ripped dvds when converted to avi out of sync
By angryassdrummer in forum Video ConversionReplies: 3Last Post: 9th Jan 2012, 07:43 -
AVI once converted has sync issues. Please Help!
By Marts1988 in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2011, 02:45 -
Converted Files To DVD Format Stutter ?!?
By Umbrella420 in forum Video ConversionReplies: 13Last Post: 8th Jun 2010, 08:20 -
By Umbrella420 in forum Blu-ray RippingReplies: 0Last Post: 7th Jun 2010, 21:28 -
Youtube MP4 Videos Converted to AVI Have Out-of-Sync Audio
By ConverterCrazy in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 17:31
