I have about 400 *.avi files on my computer, all of which used to play fine. Now, all of the sudden when I play them in either windows media player or windows media player 2 all I get is audio, and no video.
So, I uninstalled all my xvid and divx codecs, went and downloaded the latest versions of said codecs, and then installed them....... I'm getting the same thing, audio with no video.
If you have run into this problem before or know how to fix it, please let me know.
Thanks,
papaholmz
Have you installed any codec "packs" lately? That's where there are several codecs all installed at the same time. These things are notorious around here for screwing up people's systems.
Uninstall *all the codecs you do not need and do not use (I'd wipe them all completely and then reinstall xvid and divx again). Then only add new codecs as needed. -
I can't give you much advice except to give up on Windows Media Player and try something like VLC media player. It uses it's own codecs. If it doesn't work, you have a serious codec problem. If it does, you just have a codec problem.
Could it be that they might be DivX 3 or something ? You might need an older DivX codec to play them.
https://www.videohelp.com/play.htm#identify will tell you specifically what codec you need to play them. Chances are that same codec is under codecs in the tools section here
If in doubt, Google it. -
Keep the new XVID codec installed, and...
Install FFDSHOW http://sourceforge.net/project/showfiles.php?group_id=53761&package_id=59355
mkv won't play to end in Windows, but plays fine in OS X ??
By Sportyyyy in forum Software PlayingReplies: 5Last Post: 15th Apr 2011, 09:32 -
WMP 10 won't play CD's the audio is all choppy sounding, mp3's are fine..
By J Tinsby in forum Software PlayingReplies: 3Last Post: 14th Dec 2009, 06:32 -
x264 audio won't play in GB-PVR or WMP, works fine in MPC
By bigshotceo in forum Software PlayingReplies: 2Last Post: 15th Apr 2008, 10:55 -
Some WMV files won't stream, but play fine if downloaded
By DVantrease in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2008, 14:49 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 22:15
